Hi guys, I was wondering i anyone knew if it was possible to get the edgeloop function to create the loop through the center of the selected faces, instead of right next to the outer ege? I realise that this can be accomplished quite easily with a simple ctrl-shift-e in 3ds max, or in another program period but If its possible I would like to do it without leaving Zbrush. Any Ideas???
BTW… I am using ZB 3.1.
Hey everyone, i just found the “crisp” button that does pretty much what I want it to do. Any one have any idea how to get one edge looped through the center of the selected group instead of 2?
Edge loops are always going to be near the outer edge of the visible polygons.
For what you want to do, try using retopology instead. You can go in and add the loop where you want it.
Thanks Aurick, I guess all I was trying to was make more work for myself along the way instead of just doing a retop @ the end.
