Cavity Map from HD Geometry?
Just curious, is there any way to get the full-rez cavity map from your HD Geometry?
You can only work on sections of your model in HD at a time, and even then, when you mask by cavity, it doesn’t allow you to save your mask to an alpha.
Any way to get the full HD mask would be appreciated.
Same problem here. Is there a way to get this done?
