Hey,
I’m having some workflow problems when taking models out of ZBrush and into Solidworks (Professional 2023 SP1.0) via a plugin called Power Surfacing RE (8_0_SW2023). I have been following up a line of enquiry with nPower (makers of Power Surfacing).
I have been using a combination of ZRemesher & ZModeler to create low poly models that I have sub divided and added refined details to. These have been exported as .obj files with one copy at SubD1 and the other copy at the highest SubD.
In theory I can open the lower subD .obj in Power Surfacing then bring in the higher subD as a reference mesh. I can then project the detail enabling Power Surfacing to convert the model to surfaces complete with all the sculpted details. (ref. How to Convert ZBrush meshes to SOLIDWORKS using the PowerSurfacingRE add-in (using ZBrush Remesher) - YouTube)
I’ve been having a few issues bring the exported .obj files into Power Surfacing since updating all our software and this is the response I have had from nPower:
“Just because the model is made of quads, it is not necessarily a SubD. SubD models follow the Catmul Clark algorithm. Z-Brush models are not SubD models. They are high poly models, which have usually millions of poygons and if you try to subdivide them, it will run out of memory because you will have billions of polygons."
I’m clearly not understanding something here. So my two questions are:
- By using the zModeler brush am I using something other than the Catmul Clark Algorithm?
- When I export the quadrangulated mesh as .obj am I failing to export using the Catmul Clark Algorithm?
I’m feeling pretty frustrated with my knowledge gap and would really appreciate a push in the right direction so that I understand what’s happening.
Many thanks
