I’m trying out vista, and so far so good except i went to install ZB3 and after the intallation I got an error msg saying.
“The application has failed to start because its side- by- side configuration is incorrect. Please see the application event log for more detail”
From what i can tell from searches online this seems to be related to MS Visual Studio, I’ve tried installing the latest 64bit Runtimes off Microsoft’s website…but so far nothing has helped.
It just refuses to run. On the Zwiki it says
"Once installation has begun you will be asked to install a C++ 2005 Redistributable Package. This package must be installed for ZBrush to run properly. If it is not installed you may get a side-by-side configuration error.
If you do not install it now and encounter a problem later you can install it from the troubleshooting folder in the ZBrush install directory."
If i manually install the runtimes and skip this step it doesn’t work.
If i dont and let it complete it doesn’t work…
Has anyone else come across this? an any fixes?
Otherwise i guess i’ll have to go back to xp64
