Cant seem to projectAll properly
I have created one high res sculpt with polygroups.
I had to dynamesh it and lost all the poly groups. I was hoping I could project the dynameshed sculpt back onto the polygrouped version. Should this be possible? Whenever I try it nothing happens though I’m not sure if i need to freeze subdivision levels of the polygrouped model.
If somebody could explain the process i should follow it would be really helpful as the help docs are confusing me.
Thanks
Spencer
So you have two meshes one with polygroups and the other one dynameshed with no polygroups. You want the polygroup sback into the dynameshed version?
1-In the polygrouped version Go to Polypaint> Polypaint From Polygroups. This will polypaint your first model with same colors as if it were polygourped.
2-Then in the dynamesh version Project All and say yes to polypaint information. Then Go to Polygropus> From Polypaint
