hi!!! i recentley downloaded zapplink from zb central, but wen ive installed it, it isnt under documents in zbrush. why is this? i really want to use zapplink!!! please help meeeeeeee!!!
It’s probably installed incorrectly.
After downloading the zip file, you had to extract it. This created a folder with the ZAppLink file in it, and another subfolder with the ZAppLink data. There were a few other things as well.
Odds are that you just copied the whole extracted folder into your ZPlugs folder. So it would look like:
ZPlugs
-----ZAppLink Folder
----------ZAppLink.zsc
----------ZAppLink Data
The problem is that ZBrush can’t see anything beyond the ZPlugs level. You should install it like so:
ZPlugs
-----ZAppLink.zsc
-----ZAppLink Data
Also, make sure that you have the most current version of ZAppLink. I recommend that you download it from here: http://www.pixologic.com/zbrush/zapplink/
