can't sculpt on mesh extraction
I’m wondering if it driver error or error in my system. I’m pretty new to Zbrush. When I try to sculpt on the mesh extraction it doesn’t always work. Sometimes it will work on the edge, but other times not at all. That is pretty useless. What is up? Once when I turned the computer off and then back on I got it to work. Is it a bug? A setting? Driver error?
I’m working on the 3.5 on the PC
Thanks in advance.
there’s a quirk with 3.5 that when you make a extraction it still has a mask on it, just do a clear mask and that should allow you to sculpt.
I did notice that, and I’ll check to see that the mask is clear. It seems to make masks, or mask things when I don’t want them. Thanks for the input.
Bridgette
