Cant Polypaint to texture
When I try to press the Polypaint -> texture button my zbrush hangs. I am on an iMac 2.8 Core 2 Duo 4GB RAM and Zbrush 3.2… whats the problem? is there a memory issue? should i adjust my Zbrush memory configs? PLEASE HELP!!! Thanks.
Did this work before?
Did you try to delete the assigned UV’s, have Zbrush make new UV’s and try again?
