cant make displacement map need help urgently
hey guys im a bit of a noob, but iv created a model i want to import into lightwave but when i go to make a displacement map the create displacement map button is blanked out.
all othe rmodels i have ever made and even test made to see what this issue was about all were allowed the create displacment map button but this one model i cant even attempt to make a displacment map for.
id really appreciate some help asap guys
cheers
Are you using the Mac 3.12? If so, then the button isn’t available because ZBrush sees that the model has no UV mapping. You’ll need to assign mapping via the Tool>UV Map menu before you can create any sorts of maps.
