Im having trouble loading in font files for use with the 3d text plugin. I’m using a ttf file type. The file types are faded when I. try to load them even though the file type is supposed to work. Does anyone know why it isn’t loading the file type. Any help would be a predicated. Thanks!
I am by no means qualified to answer this as I’m new to Zbrush but I wonder if this means Zbrush only will load ott. or whatever the other type of text files there is?
Have you tried other fonts of both types of fonts files to test?
TTF is supported. But the particular font has to be already in your Fonts folder:
In Windows it is: c:\Windows\Fonts
In Mac it is: /Library/Fonts and /System/Library/Fonts
As far as I remember, any greyed out fonts in the Fonts folder may not be guaranteed to work even though they are loaded in the folder.
Having the same problem here, did you find an answer by any chance?
Unfortunately I am having the same problem too.
Having the same problem too. I’ve searched nearly on week in the web and have nothing found.
