Can't install zBrush3 in Parallels Desktop
hi all, I have a problem installing zBrush3 in WIN XP
on Parallels Desktop in a MacBookPro. When I tryed to install it says: ““Error 1606. Could not access network location \.PSF\.Home\Documents.””
I have full access to that folder.
Can anybody help me with this?
Somebody know why is this happening?
How can I fix this?
Thanks for your help :cool:
First, are you booted into Parallels before doing the install?
Second, are you installing to or from a network drive? ZBrush must be installed locally, and the installer should be on a local drive when you run it.
You probably need to set up a real partition as a WinXP disk first. I installed BootCamp with WinXp and then used Parallels with the BootCamp partition which is the Windoze ‘C’ drive. Zbrush will run from a hardware boot into WinXP via BootCamp and will also run from a hardware boot into MacOS under Parallels since it remains on the ‘C’ drive is was originally installed upon.
Thank you Aurick and Acmepixell for your sugestions, but wasn’t that. Fortunately I got it to work. I’ll describe all for anybody who may happened the same.
Resumed version: always install the “recomended installation option” and install “Parallels tools”.
Extended version: In the begining, I installed Parallels. Then installed WinXP in “recomended installation option”. But because I didn’t find the Mac shared folders, I think something was wrong and installed it again, another virtual machine. But this time I went for a “custom instalation” and I focused on this installed custom virtual machine… But I continue to not-see any Mac disk. I start asking friends and forum. A friend told me that I wasn’t seeing the shared folders because “Parallels tools” was not installed. So, I installed “Parallels tools”. Finally I start to see the shared folders (where zBrush installer was) and start installing it. At this point it says what I told you (Error 1606. Could not access network location
\.PSF\.Home\Documents.) and stop installing. At his time I got Aurick’s post and tryed what he says. Not working. Then I decided to give a try to the other virtual machine I made (“recomended” instalation) and tryed to install zBrush in it… and suddenly it works!!!
I don’t know why but the custom instalation was not good in some way. You must to go with the “recomended” instalation and install “Parallels tools”. That’s it. :smiley:
disable your shared folders and then install. You should be able to install fine and then re-enable your shares afterward. to disable/re-enable you should be able to do it from the Devices > Shared Folders > Disconnect All menu options. you can also right click on the small folder icon in the lower right corner of your parallels desktop window.
–James
:+1:
I don’t know what happened, but every time I try to install Zbrushes 30 day trail version on my mac,it will just open in–> (TextEditor) and I get just a bunch of text?
Im not sure what to do Im new to macs and was wondering do I need something to install it? or is this version only for PC?
Any help would be much appreciated :slight_smile:
thank you
The trial version is currently PC only. A Mac trial will be released shortly after the Mac version of ZBrush 3 comes out.
