Can't import image for reference
Hi, I’m using zbrush on my MacBook, I use them outside instead of my desktop.
But ever since I changed my MacBook into new generations, importing images is not working. I did select image from my folder but it doesn’t appear. Is there anywhere I can fix it or import an image for reference in a different way. This issue delayed my work as a student, plz help me out. thx
Hi @Eugene_Azrael ,
How are you attempting to import your image? If you are double-clicking it through the Lightbox interface to import it, please be aware this is context sensitive. For instance if you double click on a greyscale image it will always be sent to the alpha palette, whereas an 8 bit RGB image will be sent to the Texture palette.
You can always import an image directly into the menu you want with the “Import” option in that palette. For instance to import any image as an alpha, use the Alpha> Import button. For a texture, use the same button in the Texture palette.
If what I have explained above does not explain what you are experiencing, please contact ZBrush Support to look into the matter further.
Thank you!
