I cannot make the bottom window that has the sample tutorial files go away without selecting one at startup. It is driving me nuts. I tried going under zscript and hitting “hide”. this hides the thumbnails but the menu text stays there and doesnt seem to collapse correctly. there is a hide button in the menu text that I can’t click-on. How do I make this go-away?
problem mostly solved - If I select a tutorial icon, I can then press the hide button on the menu bar and it goes away. Now If I could make it not pop up at all on startup I would be happy.
I think you are referring to Lightbox - the new file browser. See here for a way to stop it showing when ZBrush starts:
http://www.zbrushcentral.com/showpost.php?p=718675&postcount=8
