can't exporting obj !?
Does anyone know why I can’t export an obj from the tools palette so I can open it in maya?
Is this even the correct way or do I have to load a plugin?
Thanks
You should be able to use Tool>Export.
If that’s not working, which version of ZBrush are you using? Do you have a 3D object selected, or one of the 2D or 2.5D brushes? Can you show a screen shot of your full ZBrush interface with the Tool palette open?
