Hey,
I’m modeling a human, “edit” is on, there’s only one model no submodels, nothing is masked, and everything works just fine, except right under the knees, I can’t edit. I click and drag but nothing happens and I have no idea why.
Any ideas?
Hey,
Any ideas?
From what you say it’s very difficult to tell what’s wrong. The most likely explanation is that there’s masking you’re unaware of, so press Tool>Masking>Clear to make sure.
Did you import the model into ZBrush? Sometimes if a model is very large or very small it can cause problems.
Ok this is weird, I clicked Tool>Masking>Viewmask and it’s indeed a masked area, but clearmask doesn’t work?
I can mask another part and clear it but the mask under the knees just wont go.
And no, I made the whole thing, but Im not sure how big or small it is.
Try using the Unify function on a copy(to eliminate scale related problems) after trying to clear any masking. You could save it as an .obj and reload it. That should eliminate any masking. HTH
