Can't edit existing Zscetch in saved ZSphere Tool
A ZSphere tool I saved yesterday crashes ZBrush whenever I try to edit ZScetch within it. Sometimes ZBrush crashes even when I load the tool. Can someone Load the tool for me & optimise the ZScetch(if it allows) & repost for me? First time back to Zbrush in ages & It’s looking better than ever!
Try this version.
Thanks a lot Marcus, that worked a treat! How did you fix it? I didn’t optimise it while modeling not sure if it caused my problems. Thanks again
I don’t know what was causing the crash but I noticed that it happened when I tried to draw the model on the canvas, not when the ZTL was loaded. So having loaded the ZTL, I pressed Shift+A to enter ZSketch mode then drew the model out. At that point everything worked OK.
