Here is my issue -
1 -I draw a sphere on the screen.
2 - I enter EDIT mode and make it a polymesh.
3 - I go down to SURFACE > NOISE
4 - I click EDIT to edit the noise.
5 - Now the problem. The edit window for applying surface noise cannot be moved around at all. The top bar of the window which is natively used for dragging a window is out of my view and I cannot even see it to grab it with the cursor to drag it down. The reason this is a big problem is because the top of the window is getting cut off, so I can not able to access 2-3 options to modifying the noise on my model.
small_orange_diamond
What can I do about this? Anything? I already tried reinstalling and that does not work. The window is still in the same place when I start zBrush - Please assist.
If you need a screenshot of the problem, just ask I will post one. Thanks for any help.
