I have been having problems in Zbrush4R2 where my obj file will not move around in Zbrush whenever I click the move button. It will not scale either, and for a while it would not let me even rotate in around in general. I tried to load the tool but it said error, then I tried importing it and it wouldn’t work either. And when I pressed the F key while still in Edit mode it brought up another copy of my file instead of just centering it on the canvas. Also whenever I activated the smooth brush tool it would not work whenever I pressed the Shift key. Same with the undo (command+Z) it would not work. This problem is intermittent, works sometimes and other times I encounter these problems. I am on a iMac OS X. 10.6.8; 2.8 GHz Intel Core i7 Processor, 8 GB memory
alienfull2.OBJ.zip (322 KB)
