cannot subdivide a file....?
ok…i have a mesh that i’m working on in zbrush…i subdivided it up 4 levels…i did my work…saved the tool and quit out of zbrush.
when i came back to work some more, i opened the tool back up and began working again…on the highest level. i then decided it was time to subdivide again…and got this message:
Note: A 3D Mesh with Subdivision-history may be partially modified only while the lowest subdivision level is active.
Switch to the lowest subdivision level -or- delete the subdivision-history and try again.
so…can anyone tell me what i need to do to be able to subdivide the model up a few more levels? i do not want to delete the lower division levels…as i will be exporting the lowest level when i am finished working.
i do not know how to delete sub-d history…but i’m guessing that would be the same as deleting the lower levels…which i do not want to do.
any help or suggestions would be greatly appreciated.
thanks,
casey
Part of your mesh will be masked first clear the mask and try and then try again.
that solved the problem. thanks a ton…not sure if i would have ever checked that.
