cannot load Topology mesh
After hours of having fun creating a new topology mesh I find I am no longer able to reload and continue, I have the mesh saved as a .ztl but when I select it from the menu nothing happens. I have various versions from different stages which all load correctly excepting the most current.
The poly counts are approximately 38,102 is there something I am neglecting? I just read in a nother post that the limit might be 25,000 so how can I reduce the count if I already deleted the lower res.
Continued searching found this link http://www.zbrushcentral.com/zbc/showthread.php?t=62688&highlight=Reconstruct+Subdiv
Problem solved!!! as far as I am now able to select topology option and it imports my mesh but the mesh does not contain the areas where I added the new topo from the higher mesh that was merged.
If I continue adding only the remaining areas can I project the details and once again append in order to get a complete model.
