Cannot load high def tool
Hello everyone, I recently run into a problem that cause me not able to open a ztool. It says Cannot load high def tool. I think the problem is i created too many subtools through extraction and it has just too many total poly counts for my system to handle. I am using zbrush 3.1 and my system setup is xp pro 3g ram duo core 2.5. Is there a way that I can retrieve the tool or extra the data in there i really dun want to loose that work. Thanks in advance for you help.
Once corrupted it is not possible to load a tool. To avoid this issue in the future I recommend using SubTool Master to save your work. It has its own Save button that includes some nice routines to help avoid this issue.
You can download it from the Download Center in my signature.
