Can you run ZBrush offline?
I’m often having problems starting ZBrush due to servers being down (like right now) or my personal internet connection failing. Is there a way to use ZBrush offline after I’ve activated the license on my pc?
Hello @Piotr_6
The server issue this morning was an anomaly. Once your copy of ZBrush is registered and activated, you should have no issues running it offline.
Be aware of this issue though, and make sure you have the most up to date version of the program:
If you are running the most up to date version of the program and still having trouble running it, you need to contact Pixologic Support.
