Can you hide by mask...?
If I have an object on the stage and there is a left obj and a right obj, can I mask the left obj, hide it and export only the right obj?
Or is there another way to hide the left and export the right?
Thanks!
Once the stuff you don’t want is hidden, then look for Tools/Geometry/Del Hidden. This deletes anything hidden. You can then export your mesh and anything that was deleted will not be exported.
Also, you can split up hidden objects into their own groups and selectively hide and show them, make them into a subtool with other polygrouped items and use the eye icon to hide them. Anything that is not visible when you export a subtool does not go with the export. Only the subtools that are visible. This way you don’t have to delete anything.
Just hide what you want to hide, make everything you want to be one Polygroup visible then go to Tool/Polygroups/Group Visible. Now you have a basic polygroup. You can then simply go to Subtool/Split Hidden and now you’ll get a seperate subtool from anything that was hidden. To export just the visible stuff, you turn off the eye on any subtools you don’t want exported and turn on the eye for any you do, then export. There’s a few more ways than that but those should do the trick.
