Can we no longer save a rig in Transpose Master in 4R6?
I do apologize for asking so many questions regarding newer versions in ZBrush. I am trying to limit them by googling my problems first and looking at the results of the query.
I have created a rig in an exercise and reached a point where it says to go into Transpose Master and save the rig using the Save TM Prj button. Well lo and behold…there is no Save TM Prj button.
Is there an alternative so that I do not lose the rig I created using zSpheres?
Thanks…
You could save the rig as a .ztl file to load later or save the project and it will be there when you open it again :wink:
The Save TM Prj button was removed because all the Transpose Master data is now stored in the project. All you need to do is save the ZBrush project (press Save As in the File palette).
thank you both very much.
