hello! can someone explain why i can`t sculpting on grey part mesh after resizing colony (using move tool)?
looks like a mask is still active
tool>masking>clear
not working…still freez for sculpting!(
If you have cleared the mask, then I don’t have any thoughts as to why you’d be unable to sculpt. You’re sure you pressed the Tool>Masking>Clear button?
If you’re talking about the area surrounded by red lines in your image, you can’t sculpt it because there aren’t any vertices [points]. The points are all at the top and bottom of the column, with only edges between. You need points evenly distributed to be able to sculpt. If you turn on polyframes (Shift+ f) you’ll see.
EDIT: here’s a picture at low res:
thanks i`m understand
