Can I scale an object along only 1 axis? [Answered]
Hi All,
Ive really searched for this to no avail.
this is so easy in Max but I cant figure out how to do it in Zbrush.
Please let me know if this is possible.
thanks
Jinda
Use the Size slider in Deformations subpalette. You can select the axis to use on the slider.
You can also use the inside end ring on the Move (W) transform (Stretch) using Shift to constrain/snap the Action Line to an axis and then Shift to constrain the Stretch along the Action Line.
I have no idea how to put it into words, but it can be done. This might help, http://www.pixologic.com/docs/index.php/Transpose:_Scaling_a_Model
perfect
thanks so much
Jinda
