When I open the noise interface, the top is too far up on my monitor and I can’t see some options.
1920x1080
The Zbrush interface is fine, its just when I open noise, it opens too high up. Is there a way to adjust it?
If not I will reinstall Zbrush and hope it is fixed.
Have you tried to open it with the noise button near the bottom of your screen? Custom UI here, I just did a test. copied the button to a low spot on the left shelf, when clicked, the panel opened lower than the original button on right shelf up higher. Might help.
Thanks Doug, just tried moving the noise tab to bottom and it now works.
Good thinking Sir!
