Can I Fix Bad Geometry In Zbrush?
Is there a way to fix bad geometry in Zbrush? I have a model that I’m working on that I messed up early on. It looks really bad around the mouth, nose and cheek areas. I know why it’s bad and what to do next time, but can I do something within Zbrush to make it better without starting over?
you can retopo the model inside of zbrush. There are a ton of tutorials on how to do it, just do a search.
the speckles are caused by your shader, not the polygroups from the looks of it.
