Can I change vitual memory location to "raptor drive"
Is it possible to relocate the ZB virtual memory folder to another drive. I have a high speed raptor drive that I believe would improve performance. If so, how does one do this?
For performance reasons, ZBrush uses its own virtual memory and the folder that it writes this to is located in the ZBrush 4 folder. It is not possible to change the destination at this time.
If you wish to take advantage of the Raptor drive(s), you’ll need to install ZBrush there.
