can i change default stroke settings?
when i use the stroke i always have the radius around 60+ i have to change that every single time i open zbrush…is there a way to change settings for tools somehow and it remember those settings? asking because i do change some stuff over and over so much it gets annoying.
http://www.pixologic.com/docs/index.php/ZBrush_3.1
All brushes are now represented by icons. Each brush can be saved as you modify its settings. Save the Brushes in the ZStartup/BrushPresets to have them load automatically at startup.
