Hello,
I had a question: low level Cage will be always the same if hi rez subD is not changed?
In other words, if I had worked on the file a while ago in the same release of Zbrush and now I see that I need to export higher resolution normal map from level 3 cage, if I load the file and get to level 3 cage, it is exactly the same level 3 cage that I had before?
I say it since sometimes, some command in some softwares give outputs that look like they are the same but actually they are a bit different…
Thanks,
Sepehr
