Bugz! (answered)
I didn’t see a bugs thread.
Don’t kow if this is a bug or
an ID-10t error…:stuck_out_tongue:
  • Create a new window sized doc.
  • Then, doube it’s size
  • Hit Ctrl+0 for AAhalf
  • Drop a tool on it. (joke censored)
  • Save project
  • Close Z, ReOpen Z and load said saved project.
  • BUGZ!.lol The project seems to not be saving, loading and displaying properly so is it me or is it a bug?
Thank you,
~MAH~
I tried this and it is working correctly for me.
What is exactly the issue?
Not sure. let me explore more…I’ll let you know.
As I always say, I could be mistaken.
mtb
i made a test with: and no problem here…
Okay, now that I have had some sleep. Tried it again.
Here is the issue. My ZBrush is not saving my specific document size settings with the project.
To avoid a whole bunch of doc size numbers, let me simplify this if I can.
Window size is Zero (0)
Doubling its size Two (2)
AAhalf is One (1). not a Zero but a one because it contains double the data.
Saving this project set to 1 loads this same project as 0 and then drops it down to AAhalf (-1).
So, as I said, ZBrush is not saving my specific document size settings in the project file. It does when saving a Doc but not a project. I don’t know about you but I haven’t saved a doc since project files were introduced.
Hope that helps explain things.
This isn’t really a bug. maybe a quasi bug :stuck_out_tongue:
Before saving your .ZPR turn off “WSize” under Document. This will let zbrush save/load the correct document size from your .ZPR
Tada!!! Thanks man, that did it. It’s a bug though…but that did it all right.
