Hi guys!
There are still things in zBrush that I don’t fully understand
and I’m not sure if they are bugs or I’m just doing something wrong.
Have you ever experienced having a mesh with higher resolution and you can’t delete them?
I wouldn’t mind it, but, it’s causing me a problem,
like when I accidentally press ‘D’, it goes to that higher res,
and zBrush starts to move slow…
When it’s in its higher res form, I can’t smooth the mesh properly,
and even some crease and cut brush won’t work properly.
It’s having a hard time carving into the mesh…
See how the ‘Del Higher’ button is grayed-out?
Even if I go to the higher res form,
the Del Lower button would be the same as well.
