BUG: texture library in lightbox is black?
Hi, i would like to ask for a solution. I have vast amount of texture library, this has been my problem since i have started to use zbrush. Its not usable since when i click the black images, it bugs out t he spotlight and wont show the texture.
I decided to find a fix now, and i havent found one in days.
I noticed that my alpha library works with .psd
I would really love to add all my textures on lightbox, most of them are .jpg.
Anyone know how to fix this, everything is black including the once that are free on intitial install of lightbox.
I only have this problem on lightbox, manually exporting them is working fine and also copying my textures to zstartup also works ok, but since i have many textures, adding it preset texture is not good option.
Im using default r6, with few zplugin (goz for blend, matcap baker).
Updating to 4R6 P2 will fix it. Open ZBrush and go to “Zplugin > Auto Update” and click “Check new updates”.
Ok, i have found an update, will it mess up with my settings?
Do you by chance know how big is the update?so that i can set a schedule.
It will not mess up your settings and will only take a short time to install. It is only a bug fix and not a major install.
