Repeatable crash in ZBrush 4 r4 on a Mac running OS 10.6.8.
Turning on curve mode for the insert cube brush consistently kills the program.
Processor: 2 x 3 GHz Dual Core Intel Xeon
Memory: 8 GB 667 MHz DDR2 FB-DIMM
Has anyone else seen this?
Thought I would just do a test and I agree, mine had a serious hangup. Had to reboot.
System
Window 7 64 Pro
I7 -3.20Ghz
24GB Ram
2 x GPU’s
Now there seems to be a bunch of crashing going on, unrelated to the brush cited in my first post. I just got a crash after saving a file. Below are some of the details.
Process: ZBrushOSX [347]Path: /Applications/ZBrushOSX 4R4/ZBrush.app/Contents/MacOS/ZBrushOSX
Identifier: ZBrushOSX
Version: ??? (4.4)
Code Type: X86 (Native)
Parent Process: launchd [125]
Date/Time: 2012-08-11 14:36:55.294 -0500
OS Version: Mac OS X 10.6.8 (10K549)
Report Version: 6
Interval Since Last Report: 153627 sec
Crashes Since Last Report: 10
Per-App Interval Since Last Report: 56092 sec
Per-App Crashes Since Last Report: 10
Anonymous UUID: B2870ADD-35B1-4513-86DD-A1EF5E7F7FB6
Exception Type: EXC_BAD_ACCESS (SIGBUS)
Exception Codes: KERN_PROTECTION_FAILURE at 0x0000000000000000
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Thread 0 Crashed: Dispatch queue: com.apple.main-thread
Thread 1: Dispatch queue: com.apple.libdispatch-manager
0 libSystem.B.dylib 0x90940382 kevent + 10
1 libSystem.B.dylib 0x90940a9c _dispatch_mgr_invoke + 215
2 libSystem.B.dylib 0x9093ff59 _dispatch_queue_invoke + 163
3 libSystem.B.dylib 0x9093fcfe _dispatch_worker_thread2 + 240
4 libSystem.B.dylib 0x9093f781 _pthread_wqthread + 390
5 libSystem.B.dylib 0x9093f5c6 start_wqthread + 30
Thread 2:
0 libSystem.B.dylib 0x90947aa2 __semwait_signal + 10
1 libSystem.B.dylib 0x9094775e _pthread_cond_wait + 1191
2 libSystem.B.dylib 0x909472b1 pthread_cond_timedwait$UNIX2003 + 72
3 ZBrushOSX 0x074bdf50 __kmp_launch_monitor(void*) + 544
4 libSystem.B.dylib 0x90947259 _pthread_start + 345
5 libSystem.B.dylib 0x909470de thread_start + 34
I had posted elsewhere about administrator/memory problems when I was on my work PC, but I’m on my Mac right now. Does this look like a similar issue? The “Exception Type: EXC_BAD_ACCESS” sounds suspect. I’m the only one who uses this computer, and there shouldn’t be any problems with this thing writing to any folder/drive.
Any help is appreciated.
-Adam
Got the same result, crash with insert cube and insert cylinder when curve mode is on.
Mainboard : ASUSTeK COMPUTER INC. P8Z77-V
Chipset : Intel Sandy Bridge
Processor : Intel Core i7 2600K @ 3400MHz
Physical Memory : 16384MBDDR3-SDRAM
Video Card : NVIDIA Quadro 2000
Hard Disk : M4-CT128M4SSD2 (128GB)
Hard Disk : Seagate ST1000DM003-9YN162 (1000GB)
Operating System : Windows 7 Professional Professional Media Center 6.01.7601 Service Pack 1 (64-bit)
DirectX : Version 11.00
Windows Performance Index : 6.9 on 7.9
stone3D & Treece:
What are the exact errors you see when you do this? Or is there no error and you just see ZBrush locking up?
No error message.
Sorry for delay. No errors displayed. Zbrush doesn’t lock up, but it’s as if I’m working on a computer that only has 512mb of ram and a rubbish processor, if that makes sense? It’s as if it’s trying to use all computer resources to carry out the calculation. Very slow and jumpy when moving the mouse cursor. Even trying to go into task manager to try and end zbrush took ages.
