Brushing on the bottom of a subtool problem.
ZB4R6
Hi
I am having problems brushing on the underside of a model. That is when you orbit and try and work on the underside. The brushes loose pressure. I used to think this was because another tool may be in the way (visible of not). It may be a setting I am missing. Anyhow any advice on this would be a big help. I cant find people with similar problems on the net so I think it is just a setting I am missing.
Cheerio
Edit: testing I found out it is only the standard brush that is affected, must be some kind of setting.
In the Brush pallette are modifier settings, not all go with each brush. Maybe your model thickness is being part of the problem. While the standard brush can add material, the clay buildup or clay brush might work better. You didn’t post a picture or really explain what is happening enough for me to guess further than that.
Thanks Doug.
Yeah the brush just stops working when sculpting or painting on the underside of objects. I posted before testing properly and all the other brushes work just fine so it’s no biggie :slight_smile:
Thanks for your reply.
