It’s very handy to use “smooth” by pressing shift.How can I use other brushes like this(not changing but adding brush by clicking some button)
For example I am using “clay” then press shift and smooth my sculpture,then press “any key” and use “standard” than release and continue to sculpt with “clay”
You can’t do quite what you’re after. But you can assign hotkeys to specific brushes. For example, you could use 1 as the hotkey for your standard brush and 2 for the clay brush. Shift will continue to activate smoothing regardless of the current brush.
(You can change the brush that’s activated by using Shift, though. This is done by Shift+clicking on the desired brush.)
I know it, but I’d like to use 3 brushes at once.
Because it’s rather difficult to change them during sculpting, even using hotkeys
not sure but maybe you could make a macro that would toggle between two specific brushes.
why not just move the brush icons to somewhere more easily accessible within your workspace?
ok,I’ll read something abaut macros, anyway it’s stsange that we can’t add other brushes like smooth one. it’s a pity
