I’m getting some weird behaviour when changing the active brush. I have a bunch of custom brushes along with the standard ones, I’ve set some shortcuts for them, but it seems that sometimes, when I change the active brush (no matter if I do that by a shortcut or by a button), not all the brush parameters get changed (sometimes the alpha stays the same, the intensity and I guess other parameters do that too). Is that a normal behaviour? (brushes randomly not setting their own parameters?). I suppose not. Is there another “not to” involved I should have known about or is there something I do without realising? Thanks.
And one more thing. What the “Brush changed with current settings intact” message mean?
I often get this message when changing brushes.
I think what you’re getting is about right.
In 3.1 some brushes adhere to a “Global” settings while others adhere to own (local) settings. I think this is due to how the brushes do things. For example, the clay seems to displace pixols using different algorithm as say, the standard brush and thus uses different parameter (programming-wise).
Or, it could be one of those things that got broken in Z3 series. Though I doubt it for 3.1.
Let’s see how the Z3.1 mac goes.
Hmm that’s weird, because sometimes it works perfect (the parameters change). But other times, things go wrong. I won’t be able to see how zbr for mac will handle that, since our pipeline is based on win xp.
Boy, i have this problem too!! isn’t that nice
Select alpha on one brush, it copies it to another when i switch to it, then i get rid of it, sculpt, go back to original brush… alpha is gone.
nice
the reset brush plugin does not solve this problem
(as mentioned in another thread related to this topic)
m
I said it helped with the problem. The plugin will restore whatever brush settings you save using it, which includes alphas.
right, marcus
there´s a difference between helping and solving
and the reset brush plugin definitely helps
I didn´t want to bother you, it´s just that I have lost so much time with ennoying zbrush bugs (and most of them aren´t even bugs, nobody can tell me, that there ain´t no way to switch between brushes without losing the settings - from a programmers view)
it´s just a bundle of attributes which need to be stored.
I just don´t get it why things like this are not beeing taken care of by Pixologic.
regards,
m
I can assure you it is a known issue and is being dealt with.
This issue can be quite a headache. Fortunately I’ve found a fairly simple workaround to deal with it using macros.
