Brush Stroke with Curves?
Still having trouble with the documentation I can’t find my answer anywhere.
I always RTFM but unfortunatly I don’t have any luck with zbrush documentation.
So I am trying to use a curve and make a stroke with it, it is like photoshop when you use patch to make brush stroke.
The only way I found is to move the curve a little bit.
It is the way of doing it or is there an other way that keep the curve at its position?
I’d love to hear that.
Thanks
Just click once on the curve or small end ring to update the stroke. It’s easier with a mouse, but can be a little tricky with a pen as there is a chance of moving the curve a small amount.
Thank you, that was what I used to do but never thought that it was because I was using a tablet that it can cause my curve to move.
I assumed zbrush was fitted to work with pen tablet.
So I’ll have to click with my mouse, thanks.
