For some reason the hot key for brush size increase decrease doesn’t work for me. I use [ and ] to control the brush size,
but now when i push on it, nothing happens.
Is there a reason why it stopped in version r7?
It still works for me on 4r7, although I never use those keys to change the brush size. I would suggest holding the spacebar and changing your settings through the brush pop-up menu. It is much faster.
For some reason those hotkeys can be lost with the default installation but you can easily restore them. Simply reassign the hotkeys:
Thank you guys it worked!
It auto unassign for some reason like you said, so I had to redo it again.
