Brush Re-sizing Hotkeys disabled?
In Past versions of Zbrush, by default I could always use the arrow square brackets;
[ = up ] =down
to resize my brush on the fly without having to pull up the spacebar menu or moving to the top of the screen to access the slider. In 4R4 it appears to be disabled and it’s not something that is as simple as assigning a single hot key, since it is a floating value.
Am I crazy or is anyone else noticing this?
Help please, I want my square brackets back!
thanks,
s
If you don’t have those buttons, then you probably don’t have version 4R4 P2. If you only have version 4R4, then click on ZPlugin>Auto Update>Check new updates. If you don’t want P2, then I can upload the plugin that has those buttons and the increment slider.
