Brush problem
Well I’ve been working on a wall adn want to make it look lite a stonewall. Anyway, i’m using the claytubes brush most, but when I was about to start sculpting on the other side of the wall it looks like this. see picture
It’s like when I drag vertical it get double size, can’t really explain but I think the picture says it all.
Please help me with this because i can’t work like this :frowning:
Cheers,
Jimi
I’m sorry, it doesn’t.
You mention that it’s happening when you sculpt the other side. Do you mean that your sculpt is going all the way through the model? If so, turn on Backface Masking, in the Brush palette. That will prevent the sculpting brush from affecting both sides of a thin surface.
Ok, sorry if I was blurry.
It doesn’t affect the other side.
Here’s another picture:
As you can se I have done the same sculpt on the two wallsides and the right side it’s normal and the left side it’s streched. But just when I sculpt vertical that it looks like this.
Little update:
I just tried to rotate the model 90 degrees and it works, but the problem moves to the top location so it’s still there. What I will have to do is to rotate the model depending on where I will sculp, then it will work. But if there’s a solution to this I would be glad :slight_smile:
