Brush pen pressure settings?
Is there any way to turn off opacity pressure while keeping size pressure? Im trying to make a sharp line in polypaint, but the opacity pressure is annoying.
example: http://image.prntscr.com/image/3703506323d242b2a89e2d26a647a107.png
I want my line to look like the top line not the bottom
You can do it by adjusting the RGB Intensity curve in the Brush>Tablet Pressure menu. Note that these settings are per brush. If you want to use the settings in the Preferences>Tablet menu then you need to turn on Use Global Settings in Brush>Tablet Pressure.
I’ve attached an example brush for you to try. Unzip and save the ZBP file to the ZBrush 4R7\ZStartup\Brush Presets folder if you want the brush to be available each time you start ZBrush.
