Hello,
Has anyone else noticed that the ‘brush modifier’ setting, which for non-standard brushes is described as setting the max elevation a brush stroke will reach, has no effect on clay brushes?
I tried 0, and I should see no effect with a clay stroke, but I see it pushing up the surface on each stroke.
I tried -100, and I still see the same positive elevation on the surface (instead of a subtraction in elevation).
I tried various values between 0 and 100 and the surface is pushed up by the same amount, regardless of brush mod setting.
I reset all brushes before testing. I’m using Zbrush 4R8 Patch 2 on Windows 10.
Thanks,
