Brush intensity after saving tool (answered)
Hi all,
When I save out a ztool, I often find my brush intensity is acting as if it is much higher than it should be. I end up turning the brush intensity to 1-3 in order to replicate the usual 20 setting. If I restart zbrush, the brush intensity acts as expected.
Anyone else have this problem or know of a work around?
Many Thanks,
William
yep same here , i dont know how is in R4 but in R3 i have the same problem like many others
you don, t need to restart zbrush just click on the window botton and then click in zbrush again
this si the fast way to fix the intensyti like before save :slight_smile:
good luck
Great thanks!
:+1:
This bug has been there since always, will this ever be properly fixed or do we have to keep using this band-aid solution ?
