Brush Hotkeys
I’ve searched about but can’t seem to find the answers to my questions. First, are there hotkeys to adjust the Focal Shift of the brush you have selected. Second, is there a hotkey for the various brushes i.e. Std, Inflate, Pinch etc. Third, Is there a way to have symmetry in a certain axis (x mainly) while in projection master. Fourth, when using the Shft hotkey to smooth I find that sometimes the intensity of the smooth brush has been lowered to the value of the current brush that I’m using for some reason. I haven’t manually adjusted the smooth brush intensity value myself so something is doing it automatically. Is there a way to stop this behavior? Thanks for any help you guys can give!
…in the menu Zplugin /Zbrush Help / Help Topics/ Zbrush Essentials/ Hotkeys & Mouse Action (Pdf) :wink:
Pilou
Ps You can have any symetry when “you paint” using a 3D object inside PM
A sort of symetry with Stroke Radial or Grid when you use a brush inside PM
But a real symetry using a brush I don’t remember :confused:
But I have not a good memory :smiley:
Thanks Frenchy, I’ll try and figure out what I can in projection master, but unfortunately, none of the other questions I asked were answered in that pdf…which I had read before I posted my initial question. :confused: So again, are there hotkeys to adjust the Focal Shift of the brush you have selected. Second, is there a hotkey for the various brushes i.e. Std, Inflate, Pinch etc. Third, when using the Shft hotkey to smooth I find that sometimes the intensity of the smooth brush has been lowered to the value of the current brush that I’m using for some reason. I haven’t manually adjusted the smooth brush intensity value myself so something is doing it automatically. Is there a way to stop this behavior? Thanks for any help you guys can give!
…the right clic mouse Button and move with left pressed? It’s some easy :rolleyes:
Ps Wait a minute it’s seems to me that some one has made a script about that!
Hey Frenchy! Thanks for the heads up! I knew about the Right click menu but TOTALLY forgot the focal shift was there. Thanks! Now, as for hotkeys for the other brushes? Are there any? Also, is there a way to edit the right click menu and add brushes/menu options that you would like to it? And does that smooth thing happen to you…where sometimes the smooth brush intensity value shifts to a lower value without you having manuallly done it? Thanks again for your help!
…by the genius Marcus Civis
Quasi all that you want !
:wink:
And the talent of Aminuts to regroup all Zscript and Zplug :+1:
Fantastic script!!! Just what I needed!
Pilou
