Broken Mesh after decimation master...
any tricks to fix a mesh after decimation mater? It seems to break the mesh in certain areas.
When imported into Rhino after Zbrush it shows the mesh is open? Even after " close holes " options was ran. also " fix mesh ". .
thanks.
What do you mean the mesh is broken? I has holes in it?
Is it breaking on small areas, huge areas, super thin areas?
Pics?
sorry, should of been more clear… The mesh produces " NON MANIFOLD EDGES " after decimation. .
Alright, so I am assuming you’re trying to print said mesh then.
Does Zbrush show it as having any holes, or do you only see them in Rhino?
Yep, trying to print the model. Rhino has a few mesh commands that analyzes the mesh. STL programs like " Magics " can fix these kind of problems but i was wondering if zbrush had any work arounds.
Yeah, at 8k a seat it damn well better.
I close holes and fix mesh should fix it. I’m asking about Rhino because it could be an import or export error that is causing the holes to appear if Zbrush isn’t seeing them, that would be my guess.
Have you tried viewing the model in another application to see if the same issues occur in the same areas?
