Last spring I was afflicted by a subarachnoid hemmorage, a
bleed into the skull between the skull and the membrane
surrounding the brain. The effects are similar to those of a
stroke, needless to say I was hospitalized several weeks and
it has taken me a while to work up my endurance, which is
still rather limited. I was very fortunate to suffer fairly small
problems compared to most who are so afflicted.
a cintique, and a tower system with 27" monitor with a 6x11
intuos 3. Unfortunately both systems are not easy to
keyboard and tablet at the same time, and it is now significantly
more difficult. Previously that was really only a real pain
while trying to make selections. But now the smooth brush
will not activate! (Yes, due to being sidelined I am just
now figuring that out!)
This is made worse by my current physical inability to hold
up the weight of the tablets, being forced to use an easel
to hold the intuos for example.
This is particularly bad as I like to
work by sculpting for a while, then flipping to the smooth
brush and using it while occasionally while rotating and
looking the model over. Trying to hold a shift key on a
keyboard 3-4 ft away from the tablet for several minutes
while trying to work accurately is just not happening.
I would use the button on the wacom pen, but the bindings
are already used up by other functions that require key functions.
Does anyone have any suggestions?
Oh please Pixologic, you have always done such a wonderful
job with this package and I love the improvements, I can’t
wait to d/l and try out R3, but please, oh please, won’t you
restore my beloved smoothing brush? Even if all the button
does is enter and exit the smooth mode.
Thank you for your consideration,
Tom
