Hi guys…which one is better…the BEST render or BPR ??? It seems to me that they are 2 separate render engines ??? or are they connected ? Which gives better results ???
thanks
thanks
BPR is the better for 3D models. The Best render is sometimes necessary for particular materials effects but is mostly used for 2.5 paintings. If you need Best render to get materials to render correctly on a 3D model then you can do the Best render first and follow immediately with a BPR.
Hi, You mean that first I press the best render…and as soon i press bpr it combines the 2 renders some how !?
is that correct? or shall i make some operation between ? So the best is to use both _?
thanks
Just use BPR.
