Hi all,
Is there any way to get the BPR to render an image larger then the screen resolution? There are some qualities of the Zbrush Render that i really like and want to integrate into the final piece but its for print so the resolution needs to much higher (I would prefer not to upsample in PS). Along the same lines is there any way to export the Zbrush Camera and lights (or camera at least) to 3dsMax so I can layer renders from both Max and Zbrush?
Many Thanks for any help
